Full Version: Polygon to Moi what are some best practices?
Show messages: All  1-13  14-20
11 Dec 2024   [#14]
Not to hijack a thread, but I often find myself needing to import a polygon mesh into MoI just to use as a 3D reference. I'm often given 3D files by clients that I need to make a part to fit accurately in MoI, or to remodel the whole thing as NURBS, and currently there's no easy way to do this. It would be great for me if I could just import a polygon mesh even as a pretty much un-editable, otherwise useless object, just to use as a 3D reference for remodelling. There's only so much you can do (and so much accuracy you can achieve) with screenshots from each side, or extracted 2D curves imported from a polygon modelling software
Or I've modelled 2 parts of an object, one in Blender and one in MoI, that need to fit together and I just need to check fitment and scale etc
11 Dec 2024   [#15] In reply to [#14]
Hi DanC, for use as a visual reference you can use the OBJ23dmWireframe converter utility program, from here:
https://moi3d.com/wiki/Resources#Obj23dmWireframe_converter
That will convert an .obj file containing polygon mesh data into a wireframe .3dm file which can then be opened by MoI.
11 Dec 2024   [#16]
Good day..
I am working on something like this...not sub d
I was thinking of importing and perform exact booleans in Moi
I am still getting used to this kind of modeling...
12 Dec 2024   [#17] In reply to [#16]
Hi Matadem, if that's not sub-d then I would not recommend trying to bring it into MOI.
Your model data will be made up of a lot of little planar fragments.
If you then apply exact booleans your result will be a weird mix of a faceted main body and smooth only on the cuts you apply in MOI.
The main way that it could work would be if you constructed the body as a sub-d model in your poly modeling program. Then the main body would be a smooth surface in MoI after you convert it from sub-d.
12 Dec 2024   [#18]
Understood.
Thanks!
12 Dec 2024   [#19] In reply to [#15]
Thank you Michael, I'll check out that converter
15 Dec 2024   [#20]
For future reference and if I am not mistaken, here are the commands (some custom/third party) used in that video :
- "_importobj" (third party) to bring in a .obj control cage without subdivision. If it fails because of unsupported geo, subdividing the object once before import can bypass the issue.
- "_Subdiv_beta9" (also third party) to control the smoothness of subdivision
- "ImportSubD" (stock) to import a .obj with subdivision and reconstructed surfaces
- "pastepart" (stock) to place parts on surfaces.
For the third party import and subdivision scripts : https://moi3d.com/wiki/MaxScriptArchive
I hope this helps !
