Full Version: Inconsistency in trim?
Show messages: All  1  2-16
29 Nov 2024   [#2] In reply to [#1]
If i make an Array / Curve of a Point with your file i have not your result! :)
For count the radial lines select them (right to left) and see Detaisl or the up Right Page Pannel
So here 51
29 Nov 2024   [#3]
If I make your Array / Radial Lines ....Ttrim with an arc of 300° (from your text )
I have the expected result trimming!
29 Nov 2024   [#4] In reply to [#3]
Yes while you are trimming it is shown correctly but the resulting trimed arc if you keep everything joined, has additional interpolation points in the case of 300 degrees which don't appear in the case of 270 degrees. That's what puzzled me.
I simply used one line and made an circular array of 60 elements, then deleted the ones I didn't need, by the way.
29 Nov 2024   [#5] In reply to [#4]
Hi geekmidget, it's from the automatic rebuild mechanism that shows replacement edit points on circles, arcs, and ellipses so that you will get a smooth result if you manipulate the points.
Exact circles are formed in NURBS by a sequence of arcs. The actual internal control points of your 300 degree arc are like this:
The problem with this is that if you manipulate one of those points the result will have a sharp corner in it like this:
So to avoid that when you turn on control points on an arc or circle you see the points of an automatically rebuilt curve that does not have interior corner points and so will deform smoothly.
Note that the location of the corner points corresponds to the spans that you noticed have 4 control points instead of 3:
This "auto rebuild" mechanism will use the actual control points if there are only 3 points in the segment. After trimming there are more than 3 points in the curve in those spots where the segments are glued together. That's what causes the different auto rebuild behavior.
arc_edit_points1.png  arc_edit_points2.png  arc_edit_points3.png  arc_edit_points4.png
29 Nov 2024   [#6] In reply to [#4]
Points of trimming are not Points of Control ... when you join several curves
Here there are moved slighly from the trimming points
You have now the explanation from Michael! :)
29 Nov 2024   [#7] In reply to [#5]
I understand this but in both cases (270 degrees and 300 degrees) there are control points falling somewhere between two lines, however the trim gets evenly interpolated in the case of 270 degrees and in the case of 300 degrees it inserts two points instead of one in those couple of places. I thought internally arcs were saved as mathematical representations.
Sorry I was trying to reply Michael but I don't know how to use quoting in this forum UI. Is it supposed to be done manually?
29 Nov 2024   [#8] In reply to [#7]
OK So I made another related test, I used a circular array of points following an arc of 90 degrees (I added some markers for visualizing alignment), then used the freeform through points and the resulting 90 degree arc didn't respect points. So this isn't so much a trim issue as an interpolation issue.
29 Nov 2024   [#9]
As said previously you can't use Control Points as real Geometric Points!
29 Nov 2024   [#10] In reply to [#9]
I thought in the case I made a freeform curve using actual points they would be respected.
29 Nov 2024   [#11] In reply to [#10]
Hi geekmidget,
It will be if you use Draw Curve > Freeform > "Control points".
In that case the points you pick directly become the NURBS control points of the resulting curve.
That won't be the case if you use "Through points", which calculates a curve that passes through the points you pick. The control points of the resulting curve will not be the same points that you picked, they will be the result of the interpolation calculation.
NURBS curves do not inherently pass through all their control points.
29 Nov 2024   [#12] In reply to [#11]
I see, that naming seems counter-intuitive to me, but thanks! Now I get it.
29 Nov 2024   [#13] In reply to [#7]
HI geekmidget,
You seem to be trying to use the edit points as a diagnostic tool.
That's not really what they are intended to do.
In MOI the edit points are meant to provide a way to deform a curve. Since the regular NURBS control points for a precise circle or arc do not deform smoothly, there is a curve rebuild process applied to edit points. The rebuilt curve will be used if you move some of the points around.
No that's not quite correct, the 300 degrees has "actual NURBS control points" like this:
And the 270 degree has this:
The 270 degree does not have any fully multiple knots interior to a trim span, they're all at the end of a span.
The 300 degree one has 2 spots where a fully multiple knot is internal to a trim instead of at the ends of a trim, those are the spots where the rebuild points will get 4 edit points.
Yes. You can put the quote inside <quote></quote> if you want.
29 Nov 2024   [#14] In reply to [#12]
Hi geekmidget,
Well, with the "control points" method the points you pick directly become the NURBS control points, I don't follow how that's counter-intuitive.
29 Nov 2024   [#15] In reply to [#14]
Try to watch the UI from the perspective of someone relatively new to MoI3D who just sees the icons and names of tools, not realizing the internals.
29 Nov 2024   [#16] In reply to [#13]
Actually I was trying to get the curve to follow the points precisely in the plane XY first to then assign each a Z value.
quote:
You can put the quote inside [...]
Thank you!
