Full Version: Asking for an addon (Could this addon be created?)
Show messages: All  1-4  5-19
24 Nov 2024   [#5] In reply to [#4]
Oh WOOOW! I see some hope! Tanx MO.
A couple of questions for MO: so if u click on Ancient Numerical systems it will recall the .nod file?
And Why u didn't name it Node Library?
-Psygorn
24 Nov 2024   [#6]
just a thought if a button was added to Max's Moi custom ui that opened the location of nod files
and by clicking on the required nod file it would open nodeditor and load automatically.
Here is some info to this question I got from Microsoft Copilot but its beyond me.
If MoI3D had a feature like that, it would indeed make working with NodeEditor much more streamlined! While MoI3D does not natively support this functionality out of the box, we can create a custom script to achieve a similar effect. Here’s a general approach on how you could set this up:
Create a Custom Command:
You need to create a custom command in MoI3D to open the NodeEditor and load a specific .nod file.
JavaScript for Custom Command:
Write a JavaScript file to handle the opening of the NodeEditor and loading of the .nod file.
Here’s an example JavaScript code snippet to give you an idea:
// Define the custom command
moi.command.addCommand('OpenNodeFile', function() {
// Open file dialog to select a .nod file
var filePicker = moi.ui.createFilePicker();
filePicker.caption = 'Select Node File';
filePicker.filter = 'Node Files (*.nod)|*.nod';
if (filePicker.showOpen()) {
var selectedFile = filePicker.fileName;
// Check if NodeEditor is loaded
if (!moi.ui.createPanel('nodeeditor')) {
moi.ui.alert('NodeEditor is not installed or not loaded.');
return;
// Load the selected .nod file into the NodeEditor
moi.command.execCommand('loadnod', selectedFile);
// Register the custom command
moi.commandList.registerCommand('OpenNodeFile', moi.command.OpenNodeFile);
Add Command to MoI3D:
Save the JavaScript file in the MoI3D commands directory.
Add a shortcut or button in the MoI3D UI to execute this custom command.
Use the Command:
When you execute this command, a file dialog will open, allowing you to select a .nod file. The script then loads the selected file into the NodeEditor.
Please note that you need to have the NodeEditor installed and properly configured in MoI3D for this to work. This custom command is a starting point and may need adjustments based on your specific setup and requirements.
Barry
24 Nov 2024   [#7] In reply to [#4]
Hi Mo,
> I have a question for Michael:
> Is there any way to change the menuButton's arrow direction?
> When there is not enough space for menu, it opens underneath, but arrow stays on top.
So the way it works currently is that it will put the arrow below if it's in a UIPanel with dock="top", like if you change MainWindowLayout.xml and for the command bar edit dock="" to be <UIPanel dock="top" src="moi://ui/CommandBar.htm">
There isn't a way to control it separate from that but I will add in a dir="up" / dir="down" property.
But another way you can show a menu is like this:
<moi:PushButton style="padding:0" onclick="moi.ui.showMenu( 'ObjectSnapMenu.htm', this, 1, 0 );">Snap to</moi:PushButton>
The 3rd parameter to moi.ui.showMenu() is an integer:
0 = put menu below button
1 = put menu on right side of button
2 = put menu above button
3 = put menu on left side of button
And the 4th parameter is another integer:
0 = expand menu to right (when menu above or below button) or down (when menu on left or right side of button).
1 = expand menu to left or up
24 Nov 2024   [#8] In reply to [#5]
Hi Psygorn
Yes, It loads the selected nod file.
Unfortunately, my lack of HTML knowledge stopped me here :)
This is what I've done, maybe someone can help me.
First, I tried to call the "createDialog" with selected .nod url file, it worked well.
but, It needs to close and refresh the nodeeditor window every time user choose a new file.
Simpler way is to clear the graph by calling the LiteGraph methods,
but, I couldn't find a way to access to the "LiteGraph.editor" variable from "ObjLibrary.menu.htm" file.
It is necessary for clearing or starting the graph.
I'll try it later. hope someone can give me a hint. :)
24 Nov 2024   [#9] In reply to [#7]
Hi Michael
Thanks for the info. I'll try it out later. :)
24 Nov 2024   [#10] In reply to [#8]
Hi Mo, something like this for a script to find the node editor object from script running outside of the node editor dialog.
    var uipanels = moi.ui.getUIPanels();
    for ( var i = 0; i < uipanels.length; ++i )
        var uipanel = uipanels.item(i);
        // uipanel is the HTML window object that holds global variables.
       // Find the one that has "nodeeditor" somewhere in it's URL:
       moi.ui.alert( uipanel.document.URL );
If there is a global variable on the node editor dialog named LiteGraph then you should be able to do uipanel.LiteGraph.editor
24 Nov 2024   [#11] In reply to [#10]
Thank you Michael. Yes, It found the "LiteGraph" variable and works very well.
I'll try again later. :)
24 Nov 2024   [#12] In reply to [#11]
Hi Mo, also maybe instead of looking at the URL it may be better to look for that global variable existing.
Something like this:
        /* uipanel is the HTML window object that holds global variables. */
        /* Find the one that has a global variable "LiteGraph". */
        if ( uipanel.LiteGraph )
              moi.ui.alert( 'found it' );
25 Nov 2024   [#13]
I have made some progress with the use of Copilot to this point.
1) on shortcut key file opens to pick nod file.
2) Nodeditor opens automatically on selection of nod file.
3) File fails to load with undifined error.
Problem with path I think.
Here's the JS code.
function openNodeFile() {
try {
// Open the file selection dialog
var filePath = moi.filesystem.getOpenFileName('Open', 'MoI Nodeeditor files (*.nod)|*.nod');
if (!filePath) {
moi.ui.alert('No file selected.');
return; // Exit if no file is selected
// Alert the selected file path
moi.ui.alert('File selected: ' + filePath);
// Open the Nodeditor dialog with the correct path
moi.ui.createDialog('moi://appdata/nodeeditor/index.html?scheme=Light', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow);
// Attempt to load the selected .nod file into the Nodeditor
// Placeholder for actual logic to load the file
// If `loadNodeFile` is not the correct method, replace this with the correct one
if (typeof moi.ui.commandUI.loadNodeFile === 'function') {
moi.ui.commandUI.loadNodeFile(filePath); // Replace with the correct method if necessary
moi.ui.alert('File loaded successfully.');
} else {
moi.ui.alert('Error: loadNodeFile method not found in moi.ui.commandUI.');
} catch (error) {
moi.ui.alert('Error: ' + error.message);
// Run the openNodeFile function
openNodeFile();
25 Nov 2024   [#14] In reply to [#13]
you are a valiant pioneer!
25 Nov 2024   [#15] In reply to [#14]
Thanks pilou,
Hope someone will come up with the answer why the nod file won't load from the code I've posted.
Anyway good experience playing with Ai
25 Nov 2024   [#16] In reply to [#15]
Hi Barry,
Well a couple things - moi.ui.commandUI.loadNodeFile() won't work because moi.ui.commandUI is for accessing the UI in the command options area in the upper right area of the main window. Like where the width and height fields are shown when you're drawing a rectangle.
The node editor isn't located there, it's in a dialog not in "command UI".
Another thing is that you will need to wait until the dialog has finished loading before you can access it.
Also there is not any function named loadNodeFile() in the node editor.
Here is an example of waiting for the dialog to be loaded. Then I think you will need to copy the code from Editor.prototype.onLoadButton in editor.js .
var g_dlg = null;
var g_filePath = '';
function handleOnLoad() {
	// You can access LiteGraph here.
	moi.ui.alert( g_dlg.htmlWindow.LiteGraph );
    try {
        g_filePath = moi.filesystem.getOpenFileName('Open', 'MoI Nodeeditor files (*.nod)|*.nod');
        if (!g_filePath) {
        moi.ui.alert('File selected: ' + g_filePath);
        g_dlg = moi.ui.createDialog('moi://appdata/nodeeditor/index.html?scheme=Light', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow);
	// Need to wait for the dialog to finish loading before accessing it.
	// You can push global variables onto it now but the regular content in it isn't loaded yet.
	g_dlg.htmlWindow.addEventListener( 'load', handleOnLoad );
    } catch (error) {
openNodeFile();
25 Nov 2024   [#17] In reply to [#15]
Hi Barry, so although there does not seem to be a loadNodeFile() function, you can give the node editor a parameter named 'file' in the URL's search string to tell it which file to load when it starts.
Like this:
    try {
        if (!filePath) {
	// Put parameter file=path.nod in the URL's search string to have it load the file.
	var url = 'moi://appdata/nodeeditor/index.html?scheme=Light&file=' + filePath;
        moi.ui.createDialog(encodeURI(url), 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow);
    } catch (error) {
openNodeFile();
25 Nov 2024   [#18] In reply to [#15]
Hi Barry, so the part about telling the node editor which file to load using a file= parameter in the URL is a little buggy in the node editor code.
To fix it, open the node editor file init.js and find this on line number 44:
	var data = '', loadFilePath = NeParameters.file.replace(/%5C/g,"\\");
change it to this instead:
	var data = '', loadFilePath = decodeURIComponent(NeParameters.file);
Then the code to use it should go like this:
    try {
        if (!filePath) {
        var url = 'moi://appdata/nodeeditor/index.html?scheme=Light&file=' + encodeURIComponent(filePath);
        moi.ui.createDialog(url, 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow);
    } catch (error) {
openNodeFile();
26 Nov 2024   [#19] In reply to [#18]
Thanks Michael,
works fine now.
Barry
