Full Version: How to find open curves quickly? and copy quickly
Show messages: All  1-2  3-6
16 Nov   [#3] In reply to [#1]
Hi Matadem, also for finding where the opening is located on an open curve there is a plugin here that can be helpful:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2888.11
That marks the start point of an open curve with a point object.
And yes for transferring between 2 open windows use copy / paste (ctrl+c/ctrl+v).
16 Nov   [#4] In reply to [#3]
Maybe I am missing something
If I have 2 Moi3d open and I copy an item with ctr+c it ask me for pick base.
then if I go to the other Moi3d and do ctr+v nothing happens.
I checked the shortcuts and they are set for copy and paste.
16 Nov   [#5] In reply to [#4]
Hi Matadem,
Sounds like you have the Transform > Copy command set on Ctrl+C .
Set the shortcut's command to CopyClipboard instead.
Or you can also use the Copy button inside the Edit palette on the side pane.
17 Nov   [#6]
Thank you!
That script saved me allot of time.
The copy works well now to.
