Full Version: setting DimRadius to Diameter by default
10 Nov   [#1]
Hello Michael, all,
Is there a way to edit the DimRadius command (either by modifying it directly in the .js, or by using a shortcut) so that it creates dimensions as diameter as opposed to radius ? (hence removing the need to manually change from Radius to Diameter in Details after the fact).
Thanks !
10 Nov   [#2] In reply to [#1]
Hi Pior,
There's a dropdown for selecting this while DimRadius is running. You can set the default with a preset under Options > Dimensions.
- Peer
10 Nov   [#3] In reply to [#2]
Oh excellent ! The toggle in the Dimension prefs is exactly what I was looking for (of course).
Thank you for anticipating this, and for the quick support as always :)
