Full Version: 4 Vertices
Show messages:  1-14  15-24
8 Nov 2024   [#15] In reply to [#14]
Yes i can have different options! :) (free Hexagon 2)
And seems that your Create from file is very similar than the CatMull Clark ? (first on the left)
On the left i took Doo Sabin Level 2 (before Import inside moi)
I obtain the same result than Catmull Clark if I import the OBJ at level 0 so straight lines!
It's Moi that makes the subdivision (same result than Catmull Clark! :)
If I send a not subdivised file i have the result on the right! So Cool!
8 Nov 2024   [#16] In reply to [#8]
Hello 777RAVEN777,
Sorry I kinda miss the fact you are creating your "poly" model in MoI.
I was referring to poly modelling software, where you can simply add a level of subdivision to an arbitrary surface and thus create a full quad mesh.
It indeed does add complexity to the model, but it's a quick way to generate quad only topology and thus bypass some mesh loader limitation that doesn't handle ngones.
8 Nov 2024   [#17] In reply to [#15]
Right, that's how you want to do it.
The other result you're showing like this:
is because you're converting into smaller triangles and then trying to process that triangulated mesh as a sub-d control cage. That will make an extremely dense surface and also introduce a lot of bumpy artifacts so it's not a productive option.
8 Nov 2024   [#18] In reply to [#17]
Yes...was to see what it would be like the result of take a subdivided objet...
so not useful except if you want have some base design for some cool graphic extrudes! ;)
Dezine
Vizcom
8 Nov 2024   [#19]
Really dude stop posting 40 AI images in every thread you take part off, we get you excitement, but this is just stupid now ... as annoying as vegan activist !
8 Nov 2024   [#20]
Why not use new paradigms ?
8 Nov 2024   [#21]
At this point it's more good manners or forum etiquette.
Beside it's doesn't add anything to the topic right ? It's just random stuff.
You already take over the MoI discord, WIP : Pilou AI, Finished Work : Pilou AI, Pilou-gallery : Pilou AI, ressources : Pilou AI ... don't you think you push it a tad too far ?
I know you as active member for many softwares, and I know you are an helpful and chill person, bit really that AI spams is just out of control.
8 Nov 2024   [#22] In reply to [#21]
I find his work pretty inspiring - I'm in awe of some of the examples folks have posted in various threads here - and to think it comes (mostly) from this genius bit of software we're all using :)
10 Nov 2024   [#23]
For my part, I've decided not to present any more of my work on the forum, and not to make any more comments after this one. I don't want to be phagocyted anymore.
I think I'll also delete all the images I've posted on the forum.
I'd also like to ask Mr P. to remove my “FrenchStrings.txt” file from his blog.
END
11 Nov 2024   [#24]
Yep, this ai shit is so annoying, this forum has been taken over by ai spam, also leaving. Thanks for all the help.
