Full Version: Symmetry operation
Show messages: All  1  2-7
30 Oct 2024   [#2] In reply to [#1]
Hi Tover, give this attached one a try. It slices an object along the world y axis line, throws away the stuff on the negative x side and then mirrors using the y axis.
You can give it a parameter value of x to make it use the x axis instead. Set up the keyboard shortcut to have: CutAndMirror x
CutAndMirror.js
30 Oct 2024   [#3]
a sort of :)
Some cuts / mirrors + Shells
30 Oct 2024   [#4]
amazing reply speed, and thank you, this works perfectly! I found grid axes display in options and away we go! :)
30 Oct 2024   [#5] In reply to [#3]
Pilou are you suggesting I buy this slicing machine, convert it into code, incorporate it into Moi's executable and use it to do the symmetry cuts on my model?
31 Oct 2024   [#6] In reply to [#5]
Just that the new Michael function is like a true trimming machine! ;)
31 Oct 2024   [#7] In reply to [#6]
Oh yes! :D
