Hello,
the above problem occurred with all layers after copying all objects to another location.
The problem cannot be solved with the separate function.
Bye
Andreas
.... it does seem to be a problem with the V5.
Everything is fine with the project in V4.
Bye
Andreas
Hi Andreas,
Could you post an example .3dm file please?
unfortunately not at the moment.
I no longer have the file.
If this happens again, I will post this file here.
Bye
Andreas
Hi Andreas, yes if you run into it again please post the .3dm file, or you can also e-mail it to me at
moi@moi3d.com if you want to keep it private.
Thanks, - Michael
