Show messages: All
1-2
3-7
Ah. I knew it was that simple.
Thanks again Michael :)
Just one more question - I notice some folks have sub-folders in their libraries - does this version support that? If so, how are they set up?
Cheers :)
HI Raven, it doesn't support sub folders but it does support having multiple library folders.
To enable that there is a file "ObjLibrary.cfg.htm" to edit inside the %appdata%\Moi\customui folder.
It starts out with this:
Object Library;MOI\objects
You can add a line to set up additional library folders, like this:
Obj lib 2;MOI\objects2
That's display name first then a semi-colon then path. If you have a path with spaces in it you may need to put quotes " " around it.
Also the v5 beta supports displaying thumbnail images for .3dm files so you can just use the regular operating system file browser as an object library.
Magic as always - thanks so much Michael :)
Is there a limit to how many library folders it will handle?
Hi Raven,
Nope, no limit.
Show messages: All
1-2
3-7
