Full Version: Boolean problems on planar surfaces
Show messages: All  1-2  3-10
27 Oct   [#3] In reply to [#1]
Hi Joaco, if you zoom in pretty closely to this area it looks like the surfaces are not quite aligned on that side. They seem to be aligned on the other side so this surface is probably at a slight angle.
27 Oct   [#4] In reply to [#1]
There's an internal surface here, this is probably what is messing up further booleans:
27 Oct   [#5] In reply to [#1]
Hi Joaco, here's a version with that problem area fixed up. It looks like the rest of the model is ok.
I did the fix by deleting the walls in that area and making new ones by drawing in 2 lines, extruding them and using Edit > Trim to cut them, then Edit > Join:
Booleans should be ok on it now that there aren't any overlapping internal surfaces anymore.
Boolean error2_3dm.zip
27 Oct   [#6]
I will use something like that
draw closed surfaces (rectangles, polylines etc...
Trim each closed lines
Planar each closed lines for make each surface
Each surround surface with a name + color
Will be more easy as soon as project has more than 2 pieces! :)
then Flat Lines by Max Smirnov https://moi3d.com/wiki/MaxScriptArchive
Extrude
all walls are solid and can will be Booleaned...and very easy to snap at the good hight...
And calculate surace a game boy! ;)
In fact you can recreate SketchUp inside Moi3D! ;)
28 Oct   [#7] In reply to [#1]
Hi Joaco,
I second Val's suggestion to cut doors and windows into walls that have been extruded. Some time back I wrote a script to help with that: https://moi3d.com/forum/messages.php?webtag=MOI&msg=10907.1
--Larry
28 Oct   [#8] In reply to [#7]
Also subset booleans can help with stuff like this.
That's where you can select just some faces on the base object like here just the 2 vertical planes for this wall, and the boolean will only cut those faces.
30 Oct   [#9]
See this post for a new version of Fat Lines! ;)
https://moi3d.com/forum/index.php?webtag=MOI&msg=7594.49
31 Oct   [#10]
Thanks a lot to everyone! It's great to know MoI has such a supportive community. I guess I need to change my workflow to avoid these problems. In this case, I imported the original CAD plans provided by my client to model the house, but they seemed to come with some errors. All the information and tools you shared are of great help. Thanks a lot, guys. I've been struggling for quite some time with this.
