Full Version: Using Sweep on corners
Show messages: All  1-5  6-8
23 Oct 2024   [#6] In reply to [#5]
Thanks Michael. What if the actual rail had more than that one corner? Say 4 different corners. Can I use 4 different profiles or is 3 the limit?
23 Oct 2024   [#7] In reply to [#6]
Hi Billabong, there isn't any limit on the number of sweep profiles. But for this other technique you only sweep one smooth piece of the rail at a time, between 2 profiles at either end of it.
That's to avoid extensions.
24 Oct 2024   [#8] In reply to [#7]
Understood. Thanks Michael.
