Full Version: Using Sweep on corners
Show messages: All  1-3  4-8
23 Oct 2024   [#4] In reply to [#2]
Scaling by 100% worked. Thank you Michael.
23 Oct 2024   [#5] In reply to [#4]
Hi Billabong, also another possible technique is to do a sweep in 2 passes using 3 profile curves with the middle one slanted like this:
The pieces then will touch at their ends so they can just be joined with no extension and intersection needed.
The problem with that method is that the surface won't be an exact tube with a precise circular cross section at all points along the rail, the shape mutates a little bit as it travels along the rail and transitions from the circle profile to the slanted profile.
That's why sweep doesn't use that method currently but I would like to make it an option.
23 Oct 2024   [#6] In reply to [#5]
Thanks Michael. What if the actual rail had more than that one corner? Say 4 different corners. Can I use 4 different profiles or is 3 the limit?
23 Oct 2024   [#7] In reply to [#6]
Hi Billabong, there isn't any limit on the number of sweep profiles. But for this other technique you only sweep one smooth piece of the rail at a time, between 2 profiles at either end of it.
That's to avoid extensions.
24 Oct 2024   [#8] In reply to [#7]
Understood. Thanks Michael.
