Full Version: Nvil or Blender
Show messages:  1-12  13-32  33-52  53-72  73-92  93-112  113-129
1 Jan 2025   [#73] In reply to [#72]
Hi KENMO,
> Is there any information on these perplexing options during export?
Yes, it's in the help file under "Meshing options":
https://moi3d.com/4.0/docs/moi_command_reference11.htm#meshdialog
1 Jan 2025   [#74] In reply to [#73]
Thanks kindly Michael. That helped a lot.
Cheers and Happy New Year...
14 Mar 2025   [#75]
Good day.
I've been playing with Nvil for a few months now.
And the creator has posted allot of needed video's on youtube.
When you get used to this it is very fast...the model below can be done in 10 minutes. and I am not even good.
Question what are the best practices to import this model into Moi?
Export as obj and Importobj? is there anything I need to look for ?
Tnx!
14 Mar 2025   [#76] In reply to [#75]
Hi Matadem,
You'll want to export the level 0 base control cage, without any smoothing applied.
Export that to .obj format and then in MOI use SubD > Create > "From file" .
15 Mar 2025   [#77]
in case of no 3D file but only a photo and depending of what do you want to make! :)
You can use the free Vizcom
with this image
you obtain a 3D file format GLB
use the free 3D Builder (inside Windows) export as OBJ
use the free Mesh Lab for Decimate quadrangulate etc...
export as OBJ
Use the Max Smirnov _Import OBJ to import inside MOi
So maybe make another regulate inside MeshLab! :)
Tripo ai gives a terrific 3D result from an image!
with more decimated and free Instant Meshes
15 Mar 2025   [#78]
Micheal
What do you mean by export the level 0 base control?
Great info Pilou!
15 Mar 2025   [#79] In reply to [#78]
I believe it's no Subdivided! ;) (Level o)
15 Mar 2025   [#80] In reply to [#78]
Hi Matadem,
The lowest density one before any subd smoothing has been applied.
The one that is called the "control cage" in this video:
https://www.youtube.com/watch?v=ckOTl2GcS-E
15 Mar 2025   [#81] In reply to [#77]
Hi Pilou - what you show there are examples of what you want to avoid doing.
Like this result:
That comes from applying sub-d smoothing onto a control cage that has not been set up for subd modeling, it's just triangles.
The result will be extremely overly dense and will likely contain a lot of bumps and undulations in it.
It will be difficult to use something that messy to do further work on.
So I'd recommend not doing any of what you show there, sorry!
15 Mar 2025   [#82] In reply to [#81]
Yes it's for that i try to make only quads! :)
and maybe many more...and must also be repaired because there is something who is false...not a solid when Join or Union...
... but it was from only a photo!
15 Mar 2025   [#83] In reply to [#82]
All quads is one of the things you need to make a good sub-d object but it isn't the only thing.
The quads you have generated there are too small, each little quad will have a very localized effect on the subdivided mesh so it will be easy for there to be ripples and bumps in the shape. With larger quads a larger amount of the model's shape is impacted by each quad and it becomes less likely to have little bumps in the shape.
When bumps are stretched out over a large space they become much less noticeable.
It's kind of like this, here's a curve with a lot of control points, and one with only a small amount:
If I move the points around by the same distances on each, the sparse one still retains a smooth looking shape while the dense one becomes much bumpier:
Basically there is much more opportunity for generating lumpy/bumpy shapes if you have a lot of control points.
So that's again an example of something to avoid doing.
Yes, that's kind of interesting that it comes from only a photo but the result is way too poor quality to actually be used.
16 Mar 2025   [#84] In reply to [#83]
Understood! :)
22 Mar 2025   [#85] In reply to [#75]
Cool model. Reminds me of one of those 1970s-1980s Can-Am road racing cars.
22 Mar 2025   [#86] In reply to [#78]
In Blender you would export the model before you applied the Subdivision modifier.
22 Mar 2025   [#87] In reply to [#86]
Here is a car model I've been working on in Blender.
This is a screen capture of the car with out the SubD modifier turned on.
22 Mar 2025   [#88] In reply to [#87]
With SubD modifier set to level 3 and activated..
22 Mar 2025   [#89] In reply to [#88]
Another car I've been working on. Since I was born in the 1950s, a lot of my car models are influenced by cars of the 1950s and 1960s as well as American style hot rods based on 1930s cars with fendered running board and 1940s fat fendered cars.
22 Mar 2025   [#90]
Sorry but when I upload the image at Sub D level 3 I am getting the message out of space. Tried several times. Not sure what is the issue as I re-sized it and compressed the jpg and still no luck.
22 Mar 2025   [#91] In reply to [#90]
Hi Ken,
There's a limit of 50MB per user for forum attachments so the web server doesn't get too overloaded.
If you run out of space you can go to Options (on the top bar in the forum) > Attachments and delete some of your previous attachments there, or you could use a file sharing service like Dropbox/We transfer/One drive where you upload your file there and can post a link to it in the forum here.
22 Mar 2025   [#92] In reply to [#91]
Thanks Michael. Appreciate the reply. Is the 50mb limit per day or the complete total since joining the forum?
