Full Version: Nvil or Blender
Show messages:  1-20  21-40  41-60  61-80  81-100  101-120  121-129
31 Dec 2024   [#61] In reply to [#60]
I could produce a model much quicker in Groboto3D then I could in Wings3D, Hexagon or Silo. And now I can say faster than Blender.
I would often take the model into 3DCoat to add some details via sculpting, uv map and texture.
I created my Mr Bug model in a very short time using Groboto3D about 10 years ago.
31 Dec 2024   [#62] In reply to [#61]
Well I don't think they were using any sort of sub-d primitives at that time, I guess those are all 'math' primitives that are resolution free, a bit like a Nurbs sphere, or other revolved geo ... maybe it was Nurbs ? I guess Groboto was also handling the rigging right ? It's a really strange tool, not sure I personally could use it for anything tho.
It does reminds me something like Organica from impulse in the late 90's ... the metaballs era ... decompose any shape like a collection of primitives, it's a really particular exercise !
1 Jan 2025   [#63] In reply to [#62]
I use my Groboto created models for assets in e-onsoftware's Vue or to paint over in Photoshop, Corel Painter, Art Rage or Rebelle.
In this 2D digital painting I posed Mr Bug in Groboto and then did a render with the outline in Groboto. I used the render as an under painting in ArtRage.
i did this in 2014.
1 Jan 2025   [#64] In reply to [#63]
Wow - DAZ3D still offers Carrara 8.5 Pro which I forgot I purchased years ago and still have installed on my computer. Never really gave Carrara a chance as I found Hexagon to be a much better 3D modeler.
https://www.daz3d.com/carrara-8-5-pro?srsltid=AfmBOoqgQysVKj3vdiD-Qjku8wRNO2XcgkQ7MHC9S_T1uAsIhdzW96xt
Several years ago I became interested in Anim8or, but it seems the developer stopped working on it. It was also another FREE 3D modeling app.
https://www.anim8or.com/
With an online manual
https://www.anim8or.com/learn/manual/index.html
1 Jan 2025   [#65]
An youtube channel with some tutorials on Anim8or.
https://www.youtube.com/@pocketenix3d
1 Jan 2025   [#66]
Screen capture of an arch window I quickly modeled in Groboto3D several years ago.
I believe something similar could be quickly modeled in MOI3D.
However I believe Groboto3D does a better job when exporting to OBJ as most of the time they are perfect quads.
1 Jan 2025   [#67] In reply to [#66]
In the post above it shows what primitives were used to create the arch window's frame.
In this post the primitives used to create the window glass.
1 Jan 2025   [#68] In reply to [#67]
Archwindow exported from Groboto as OBJ and imported into Blender 4.3. Perhaps a little too dense and needs to be decimated or retopo'd.
1 Jan 2025   [#69] In reply to [#68]
One thing I do like in Modo is it's mesh cleanup function.
My Archwindow OBJ imported into Modo v17.1. Mesh cleanup finds a few issues and attempts to resolve them.
1 Jan 2025   [#70] In reply to [#69]
This time I reduced the quad count in Groboto3D's export to OBJ function and tweaked some of the seam options.
In Blender you can see the quad count is now more then half then previously.
1 Jan 2025   [#71]
Usually, when working with MoI, you want to get a mesh that accurately resembles the original file. So, if you design a sharp box, you get a box as output, not a soap stick.
And yes, building an arched window is done with just a few clicks. The only difference is that it's more of a 'destructive' approach, as the different boolean operations are not live.
Depending on the purpose, you might want to try two approaches. If it's 'just' a render mesh, n-gons driven by angle do a perfect job. I suggest using the .FBX format when dealing with n-gons to avoid reconstruction problems in most DCCs (.lwo is nice with Modo/Lightwave, though). Blender does surprisingly well using .obj, but it's an exception.
If you plan to add additional deformation or prepare a mesh for sculpting (remeshing), dicing the model evenly is the best choice, as you need accurate surface limits and can't rely on normals only.
They will both look the same in the viewport ...
But the evenly diced version can handle some advanced deformations.
MoI's mesher is simply the best, really. However, there is often a misunderstanding about what constitutes "good topology." Quad-only topology doesn't make much sense most of the time, especially if you are generating a render mesh. It's something you tend to stick to when doing pure poly-modeling or preparing a mesh for rig deformation (character work), as normals need to be re-evaluated on the fly in a surface
subdivision pipeline. On that matter, Groboto meshes will be a nightmare to work with anyway
1 Jan 2025   [#72] In reply to [#71]
Thanks for the post. There is some valuable information in it.
The export MOI3D options :
- Angle
- Divide larger than
- Avoid smaller than
- Aspect ratio limit
always confused me. Is there any information on these perplexing options during export?
Thanks kindly
1 Jan 2025   [#73] In reply to [#72]
Hi KENMO,
Yes, it's in the help file under "Meshing options":
https://moi3d.com/4.0/docs/moi_command_reference11.htm#meshdialog
1 Jan 2025   [#74] In reply to [#73]
Thanks kindly Michael. That helped a lot.
Cheers and Happy New Year...
14 Mar 2025   [#75]
Good day.
I've been playing with Nvil for a few months now.
And the creator has posted allot of needed video's on youtube.
When you get used to this it is very fast...the model below can be done in 10 minutes. and I am not even good.
Question what are the best practices to import this model into Moi?
Export as obj and Importobj? is there anything I need to look for ?
Tnx!
14 Mar 2025   [#76] In reply to [#75]
Hi Matadem,
You'll want to export the level 0 base control cage, without any smoothing applied.
Export that to .obj format and then in MOI use SubD > Create > "From file" .
15 Mar 2025   [#77]
in case of no 3D file but only a photo and depending of what do you want to make! :)
You can use the free Vizcom
with this image
you obtain a 3D file format GLB
use the free 3D Builder (inside Windows) export as OBJ
use the free Mesh Lab for Decimate quadrangulate etc...
export as OBJ
Use the Max Smirnov _Import OBJ to import inside MOi
So maybe make another regulate inside MeshLab! :)
Tripo ai gives a terrific 3D result from an image!
with more decimated and free Instant Meshes
15 Mar 2025   [#78]
Micheal
What do you mean by export the level 0 base control?
Great info Pilou!
15 Mar 2025   [#79] In reply to [#78]
I believe it's no Subdivided! ;) (Level o)
15 Mar 2025   [#80] In reply to [#78]
Hi Matadem,
The lowest density one before any subd smoothing has been applied.
The one that is called the "control cage" in this video:
https://www.youtube.com/watch?v=ckOTl2GcS-E
