Show messages: All
1-9
10-15
Size of flowed text could be adjusted by:
Change 2d rectangle size.
Or change text size,
Or ...
Ratio of height to width may also change, unless...
As Brian wrote it, I explain the theory to be easy understood.
Next you can tune your process as Brian wrote it if you want a better result by modifying your source or/and target surfaces.
Thank you all. I will try it tomorrow.
My preminilary result
Very good result!
Can alignment of text be slightly changed by moving and/or slightly rotating base surface?
I didnĀ“t try it.
Show messages: All
1-9
10-15
