Full Version: Fillet failure
Show messages: All  1  2-3
18 Oct 2024   [#2] In reply to [#1]
Hi Chase, yes curves can only be filleted if the 2 curve segments that touch at a sharp point are coplanar.
> Or should I find a workaround such as trimming back the segments near the desired fillet, and using the blend tool?
Yes that would work.
But are you trying to get something like this, here using Boolean difference with a 2D curve as the cutting object, then filleting the solids:
18 Oct 2024   [#3] In reply to [#2]
Ah, good to know, thanks for confirming. Thanks for the other thoughts--I do however need the wire to sweep a profile along, though.
I'm trimming off the ends and using the blend tool now and it's working fine.
Thanks again!
