Full Version: Font size of Alert box
Show messages: All  1-3  4-7
16 Oct   [#4] In reply to [#3]
> there is too much eye strain for numerous programs, not just MOI. So I should get a larger monitor.
Is the rest of the MOI UI ok for you by increasing Options > UI size?
I'lll see if I can adjust moi.ui.alert() to use that as well.
> The format would be... ?
Well, either HTML or PDF are good since they're cross platform.
If you call moi.filesystem.shellExecute( 'path_to_docs.htm' ); then that will display the doc file in the system's web browser or PDF viewer.
18 Oct   [#5] In reply to [#4]
Thank you Michael.
I bumped Options > UI size from 10 to 11, which is helpful.
The Alert box size does not seem to change.
18 Oct   [#6] In reply to [#5]
Hi Brian, I've got a fix for the next beta so the alert box will use the UI font size.
18 Oct   [#7] In reply to [#6]
That is great news!
Thank you Michael.
