Full Version: Importing to Moi3d
Show messages: All  1-3  4-5
15 Oct   [#4] In reply to [#3]
If your object is less than 10 000 polys you can try
the _importObj by Max Smirnov http://moi3d.com/wiki/MaxScriptArchive
But you must convert first your "3dm" file --->OBJ!
or the native SubD / Create ;)
For decimate OBJ itself : Zbrush has a terrific one : Decimation Master
Maybe the free online OnShape can also make that! ;)
https://www.onshape.com
15 Oct   [#5] In reply to [#3]
Hi Raven,
> Can you suggest some means of converting said file(s) into even a low res version that Moi could use?
There is a process called "reverse engineering" (https://wiki.mcneel.com/rhino/reverseengineering) but it's a very difficult process using special and expensive tools to create larger spline patches over top of a dense polygon mesh.
Or also like Pilou writes above most polygon modeling programs have a poly reduction tool. I think there's a free one in MeshMixer you could try:
https://meshmixer.com/
https://www.youtube.com/watch?v=921cDYBpuL4
But in general it's kind of a square peg round hole type thing. It's usually not suitable to work with that type of polygon data in MOI.
You can export CAD models out to a polygon mesh which will dice up the model but going the other direction is difficult.
