Full Version: ArcCAM
Show messages:  1-8  9-28  29-48  49-68  69-81
14 Oct 2024   [#69] In reply to [#68]
Michael,
I like it!
I've been messing around with NSIS today, and it is able to fiddle with moi.ini, but I don't feel comfortable with that. Having a plug-in container seems much safer.
>Len
14 Oct 2024   [#70] In reply to [#69]
Hi Len, ok I will set this up for the next v5 beta. So it will look for commands in directories inside appdata/plugins/<PluginName>/commands and will also look for startup scripts (scripts to run when MOI is launched) under appdata/plugins/<PluginName>/startup.
So you won't have to modify moi.ini for that and to install you can have it in a .zip and unzip it under appdata/plugins.
15 Oct 2024   [#71] In reply to [#70]
Will it also look for appdata/plugins/<PluginName>/scripts ?
- Peer
15 Oct 2024   [#72] In reply to [#71]
Hi Peer,
I should be able to make that work too.
16 Oct 2024   [#73] In reply to [#72]
Thanks Michael. I like this new plugin folder idea of yours.
- Peer
3 Dec 2024   [#74] In reply to [#72]
Michael,
I have added a plasma table module to ArcCAM. Any idea when you're gonna release the next beta?
>Len
3 Dec 2024   [#75] In reply to [#74]
Hi Len,
Probably within the next couple of weeks.
8 Dec 2024   [#76] In reply to [#75]
For my plasma script, I want to be able to set the cplane to a surface and translate curve coordinates to x,y values relative to the cplane. Before I write a function that takes the vectors from moi.view.getCPlane() and translates x,y,z values to values relative to the cplane origin, is there a better way to do what I am wanting?
[object MoiCoordinateFrame]
origin=0.9706,2.7112,2.7112
xaxis=1,0,0
yaxis=0,0.7071,0.7071
zaxis=0,-0.7071,0.7071
Also, is there an easy way to select the curve that makes up the surface?
>Len
cplane_test.3dm
8 Dec 2024   [#77] In reply to [#76]
Hi Len,
If you have a coordinate frame and you want to translate a point from world coordinates into that local frame's coordinates you can do this:
var local_x = frame.distancex( global_pt );
var local_y = frame.distancey( global_pt );
var local_z = frame.distancez( global_pt );
I'm sorry I'm not understanding this part. What is the curve that makes up the surface? A curve used to generate the surface with a particular command? The edges of the surface?
8 Dec 2024   [#78] In reply to [#77]
Yes, the edges of the surface?
Lets just say a cube to keep it simple. Select a face, and then have the script return the curve object which is a square made up of four line segments.
>Len
8 Dec 2024   [#79] In reply to [#78]
Hi Len, on a cube there would be 12 individual line curves. There isn't any curve object that would have 4 line segments in it but you can get a list of the 4 lines for a face by face.getLoops();
face.getLoops() returns a list of trimming boundaries. The first loop is the outer boundary of the face. The 2nd and further loops are holes.
Each loop is an object list of edges.
So for the face of a cube when you call face.getLoops() there will be one loop, and that loop will be an object list with 4 edge curves in it.
8 Dec 2024   [#80] In reply to [#79]
Awesome, thats exactly what I need! Also, having a list of the holes will simplify a ton.
>Len
11 Dec 2024   [#81]
As someone who mainly models in MoI, for CNC machining (and 3D printing) and has to export/import into Fusion360 (my god do I hate modelling in Fusion...) to use its CAM; this is a very interesting topic for me. Good luck with it. I'll be following along
