Full Version: DIM TOOL(s) increase or decrease fonts
Show messages: All  1-4  5-10
5 Jun   [#5] In reply to [#4]
Great tool, thank you.
BTW - I guess it's for Michael:
Is there a way to make an Arrow to be screen aligned too?
5 Jun   [#6] In reply to [#5]
hi mk, thanks for your feedback.
it seems the font is the screen aligned function...
im using cplane a lot but dont think its what you need, best i let michael answer this!
cheers
Stefano
5 Jun   [#7] In reply to [#6]
was curious to see we can create "screen aligned" arrows using ANSI arrow symbols..
Here are some of the most commonly used ANSI arrow symbols along with their Alt Codes and Unicode values:
Left Arrow: ← (Alt Code: 27, Unicode: U+2190)
Right Arrow: → (Alt Code: 26, Unicode: U+2192)
Up Arrow: ↑ (Alt Code: 24, Unicode: U+2191)
Down Arrow: ↓ (Alt Code: 25, Unicode: U+2193)
Double Arrow Right: ⇒ (Unicode: U+21D2)
Double Arrow Left: ⇐ (Unicode: U+21D0)
Up Down Arrow: ↕ (Unicode: U+2195)
https://www.i2symbol.com/symbols/arrows
5 Jun   [#8] In reply to [#5]
Hi Marky,
There is a setting for it which isn't exposed in the UI but can be set through a script.
If you put in this for the command part of a shortcut key it should switch the property for making the arrowhead plane rotate to face the viewer on selected dims:
script:
var objs = moi.geometryDatabase.getSelectedObjects().getAnnotations();
if ( objs.length > 0 )
objs.setProperty( 'rotateArrowheadPlaneTowardsViewer', !objs.item(0).rotateArrowheadPlaneTowardsViewer );
5 Jun   [#9] In reply to [#8]
It works great.
Thanks a million,
Marek
22 Jun   [#10]
Great Script,
Thank you
