Full Version: Boolean difference - one of those days!
5 Sep 2024   [#1]
Hi All,
I'm thinking this should be a straightforward boolean difference operation.. but no!
I'd just like to create recesses for the ring shank in the collet but I keep getting errors as above.
Any suggestions please?
Many thanks!
Gunter
oval stone east west ring.3dm
5 Sep 2024   [#2] In reply to [#1]
Hi Gunter, I'm still investigating but I think it's getting confused with some grazing edges.
Try with this attached version where I rotated the circle by 90 degrees before making the ring part.
oval stone east west ring2.3dm
5 Sep 2024   [#3] In reply to [#1]
Hi Gunter, also Trim seems to handle this case ok so using Edit > Trim to cut the pieces up followed by Edit > Join can also be used as a workaround so you can continue with your work.
5 Sep 2024   [#4] In reply to [#2]
Hey Michael,
Thank you! When you say rotated the circle by 90 degrees, could you explain which circle please?
I'm keen to figure out how to troubleshoot these issues on my own.. would you be able to guide me as to what I should look for specifically? I made sure, both parts were solid, not joined surfaces so I assumed any boolean operations would work.
As always, many thanks!
Gunter
5 Sep 2024   [#5] In reply to [#4]
Hi Gunter,
This one here:
Well the weird looking result seems to be emanating from where 2 edges are crossing each other, here:
So that's the area that I would focus on.
For just getting it to work so you can move forward you can manipulate the circle used to generate the ring surface so there won't be an edge/edge crossing there.
5 Sep 2024   [#6] In reply to [#5]
Gotcha, thank you very much Michael.
When you have a chance, I'd be interested to know what causes this issue - no rush.
Much appreciated
5 Sep 2024   [#7] In reply to [#2]
Just to let you know that there's no issues in Moi v3
John
6 Sep 2024   [#8] In reply to [#7]
Hey John,
Would you mind telling me how you got this to work?
Many thanks,
Gunter
6 Sep 2024   [#9] In reply to [#2]
Thanks Michael, I did that and it worked!
Much appreciated!
Gunter
6 Sep 2024   [#10] In reply to [#8]
HI Gunter,
As I said, I tried your file in Moi version 3 and the boolean works as expected.
I have version 3 and 4 installed on my system.
Best regards
