6-25
26-37
Alpaca
Vizcom
Hi
Can you explain me how I can implement this script.
I have copied it to the commads folder and then in the icons folder I have put a 138x138 pixels png file.
To invoke it I access my scrips window “attached image” and click on it.
I don't see any options for the examples that you put.
Hi Booleano, do you see anything happen at all when you push your button?
Is your scripts window an .htm file that you have edited? Can you please attach it here so I can see if it's a problem in launching the command?
Hi
If it is a file it is called “SidePane1.htm” and it is in the folder “commands”.
SidePane1.htm
Hi Booleano, is that possibly an older version that you posted?
The one you posted seems to stop at "Voronoi" and does not contain EdgeFlange.
Hi
Sorry I got the wrong file, this is the correct one
This file is also called "SidePane1.htm" and is in the "commands" folder
The last line of the file
| <moi:CommandButton icon="icons/EdgeFlange.png" command="edgeFlange"></moi:CommandButton>EdgeFlange |
SidePane1.htm
Hi Booleano, it looks like your button has the correct command="" value set on it.
What happens when you push the button?
Do you get an error message like this:
Or do you see a prompt in the upper right like this:
Hi Michael
This screen appears
Hi Booleano, ok that's what is supposed to happen. So you have it installed ok.
Can you maybe describe a bit more about what problem you're having?
I thought you were having a problem with getting it set up but it sounds like you're running it ok.
Hi Michael
But it only allows me 2 parameters "s" and "f"
And I want to get everything that appears in the MO example (MO_TE)
that is, the parameters of "0 1 2 3 4 5 6 7"
How is this done, I want the entire exercise
Hi Booleano,
Those parameters are options you can set up in the keyboard shortcut or button that you use to launch the command.
You would use those by putting them in to the keyboard shortcut or button.
Like for a keyboard shortcut for the "Command" value instead of putting in just:
edgeFlange
you would instead put in:
edgeFlange 5 true false 4 Auto 1 false false
For a button like you have set up instead of having command="edgeFlange" you would put command="edgeFlange 5 true false 4 Auto 1 false false"
That can be helpful if you are using the command frequently with some specific values, so you can set up different shortcuts to launch it with different default values.
Edge Flange + SubDiv Beta9 by Max Smirnov
Banana
6-25
26-37
