Full Version: Edge Flange Script
Show messages:  1-11  12-31  32-37
4 Sep 2024   [#12]
Very usefull.
Thanks !
4 Sep 2024   [#13] In reply to [#10]
Hi Mik
I think doing an unfold tool for all kinds of surfaces is just way beyond me! :) I don't have enough geometry/programming information to do this.
On the other hand, I read your thread about using flow as an unfold tool since 2015.
And I think this technique can be a good fit for edge flange script as it can produce simple objects.
Here are some thoughts:
In V5 there is a function to store user information to objects (setUserText), Also one to get the information. (getUserText)
I think it is possible to change the edge flange script to store some information like bend radius, bend start point, arc center, arc length and hierarchical order of the produced objects.
Then maybe a script can use this information to flatten the parts like you demonstrated in this thread. ( I don't know how yet! )
https://moi3d.com/forum/index.php?webtag=MOI&msg=7406.1
Here is a screenshot of using flow to unfold an object created with edge flange script. (Manually)
Right now I don't have the time and a solid plan to work on it.
Also, you can use freecad's dedicated SheetMetal Workbench and SheetMetal Unfold tool. Although, I haven't tried it myself.
5 Sep 2024   [#14]
Cool script and links!
And with SubDiv_beta9 by Max Smirnov
Will be fine if we can have this choice! ( Negative Angle or Flip Direction don't give that!
(edit see following posts that is yet possible! :)
6 Sep 2024   [#15] In reply to [#14]
It's great for HVAC ducts routes in architecture, at least in the concept design stage.
6 Sep 2024   [#16]
In fact that is working! :) Bravo!
But you must be in "Manual" and make a full rotation in "Flip Direction" before draw!
French Version
https://moiscript.weebly.com/brides-de-rives.html
8 Sep 2024   [#17] In reply to [#1]
@Mo_te
Can you make something for have the possibility to recall your script at the end ?
Because now when we make Right Click it's the Extrude function who is recalled! :)
8 Sep 2024   [#18] In reply to [#17]
Hi PILOU
The extrude part can be skipped by setting the last command parameter to true.
edgeFlange 5 true false 4 Auto 1 false true
edgeFlange 5 true true 4 Auto 1 false true
This way you can repeat the 'edgeFlange' command by right click.
But if you like to run the extrude command at the end, It will change the last executed command to 'extrude'. That's why right click repeats the extrude command.
Another option is to set a shortcut key for 'edgeFlange' command and run it from there.
8 Sep 2024   [#19] In reply to [#18]
Of course i wish run the "Extrude" at the end of the process before the "remake" ! ;)
So maybe Michael will have a trick! ;)
9 Sep 2024   [#20]
<<< Sorry no there isn’t currently a way to do that.
I have some ideas for a mechanism that would manage running a sequence of several commands in a row.
That would probably help with this case but it’s currently at the idea stage and is not implemented yet.
Michael>>>
So wait & see! :)
9 Sep 2024   [#21] In reply to [#13]
Hi MO,
never mind, Edge Flange Script is awesome itself and unfold proces it can proceed manually in several ways, as you mentioned.
I know, that freeCAD dispose SheetMetal Workbanch, but I prefer to do all my construction job inside MoI, because I simply love this piece of software :-)
Mik
9 Sep 2024   [#22]
Really nice little script, thank you for sharing!
17 Sep 2024   [#23]
Works fine with SUbDiv_Beta9! :)
_SSplit
EdgeFlenge
Boolean Union
_SubDiv_Beta9
This sort of volume will be some difficult to make in pure Nurbs! :)
17 Sep 2024   [#24]
So in free Alpaca :)
17 Sep 2024   [#25]
The good thing seems other than rectangle face can be "Flanged" !:)
Careful if the face is not a rectangle!
You must "split" it ...if possible...for SubDiv!
All takes 10 seconds! :) (sculpting) + render (5 seconds)...
So inside Alpaca :)
Vizcom
18 Sep 2024   [#26]
Alpaca
Vizcom
17 Oct 2024   [#27] In reply to [#1]
Hi
Can you explain me how I can implement this script.
I have copied it to the commads folder and then in the icons folder I have put a 138x138 pixels png file.
To invoke it I access my scrips window “attached image” and click on it.
I don't see any options for the examples that you put.
17 Oct 2024   [#28] In reply to [#27]
Hi Booleano, do you see anything happen at all when you push your button?
Is your scripts window an .htm file that you have edited? Can you please attach it here so I can see if it's a problem in launching the command?
18 Oct 2024   [#29] In reply to [#28]
Hi
If it is a file it is called “SidePane1.htm” and it is in the folder “commands”.
SidePane1.htm
18 Oct 2024   [#30] In reply to [#29]
Hi Booleano, is that possibly an older version that you posted?
The one you posted seems to stop at "Voronoi" and does not contain EdgeFlange.
19 Oct 2024   [#31] In reply to [#30]
Hi
Sorry I got the wrong file, this is the correct one
This file is also called "SidePane1.htm" and is in the "commands" folder
The last line of the file
<moi:CommandButton icon="icons/EdgeFlange.png" command="edgeFlange"></moi:CommandButton>EdgeFlange
SidePane1.htm
