Full Version: How to make frosting on a donut?
30 Aug 2024   [#1]
Hey folks. So I have my donut as one object, and my frosting as another.
How can I "drape" the frosting over the donut? I normally design machinery and hard surfaces, not something like this, so I'm at a loss.
Thanks!
Chris
donut airtag v1.3dm
30 Aug 2024   [#2] In reply to [#1]
Try the native Transform / Deform / Flow function! ;)
Bon appetit!
http://moi3d.com/4.0/docs/moi_command_reference8.htm#flow
PS Not exatly that you want but for the fun you have a cloth simulation by Max Smirnov
https://moi3d.com/download/scripts/max/Cloth.v.0.97.2017.11.23.zip
30 Aug 2024   [#3]
I would copy your donut, cut down to where your bottom drip will be (straight line) separate the top surface and shell it to make it a solid. then cut the wiggly lines on it by creating boolen operation with a separate object.
30 Aug 2024   [#4] In reply to [#1]
Hi Chris, it's possible to use Transform >Deform > Flow to do this but it will be a bit tricky. The donut would need to be rebuilt to be just a single surface revolved from a curve with just one segment in it and the base surface would need to be a revolved plane instead of a regular 4 corner point plane.
Instead it might be easier to create some cutting surfaces to cut the donut up and shell the remaining piece to thicken it.
30 Aug 2024   [#5] In reply to [#1]
Something like this -
Loft a cutting surface between 2 curves for the outside:
Loft a similar cutting surface for the inside:
Use Edit > Trim to cut the donut with those lofted surfaces as the cutting objects.
That will make a result like this which you can thicken using Construct > Shell :
chris_donut1.jpg  chris_donut2.jpg  chris_donut3.jpg  chris_donut4.jpg  chris_donut5.jpg
4 Sep 2024   [#6] In reply to [#5]
Well that was unpleasant. Thank you everyone for your help!
Chris
