Show messages: All
1-2
3-4
That wouldn't work, either. I tried solids, but no go. I was finally able to get it to work by Boolean Differencing each individual panel or surface, one after the other. Ugh... Thank you for the idea, though!
Bob
Hi Bob, I think the part where the booleans try to intersect the pieces is getting confused with there already being a cut through that same spot.
Instead of doing a boolean in this case you can select these faces and delete:
Show messages: All
1-2
3-4
