Full Version: Boolean Difference won't work.
Show messages: All  1  2-4
18 Aug 2024   [#2] In reply to [#1]
Make a big box (top & bottomdown) from your rectangle
kill or hide all curves
Boolean Diff
Kill the rest
18 Aug 2024   [#3] In reply to [#2]
That wouldn't work, either. I tried solids, but no go. I was finally able to get it to work by Boolean Differencing each individual panel or surface, one after the other. Ugh... Thank you for the idea, though!
Bob
18 Aug 2024   [#4] In reply to [#1]
Hi Bob, I think the part where the booleans try to intersect the pieces is getting confused with there already being a cut through that same spot.
Instead of doing a boolean in this case you can select these faces and delete:
