Full Version: ACIS kernel in MoI V5
Show messages: All  1-3  4-7
11 Aug 2024   [#4] In reply to [#3]
Hi mdesign,
> Have you thought about some rebuild edges, surfaces or matchcrv,
> matchsrf took from ACIS (if it`s possible to take it from kernel)?
Unfortunately MatchCrv and MatchSrf are not really part of the regular Mechanical CAD toolset so ACIS doesn't have these in it.
26 Sep 2024   [#5] In reply to [#4]
Have you thought about some poll for MoI users to check which most favorite/useful commands from ACIS could be transfered to MoI3d? Offset and shell are my favorite together with fillet. That`s because I have with them most problems. Sometimes If I have problems with Rhino then I try in Plasticity or Solid Edge if it would fail too, then I would have another kernel to check.
I know that best would be correct surfaces but sometimes when I have not enough time changing kernel is a solution to save some time and have job done and It saved me few times.
26 Sep 2024   [#6] In reply to [#5]
Hi mdesign, I do want to use offset and shell from ACIS as well, I'm still working on fillet first right now.
26 Sep 2024   [#7] In reply to [#5]
Have you tried IronCAD ? It makes use of both math kernels - ACIS + Parasolid !
https://community.ironcad.com/index.php?/topic/16565-dual-geometric-modelling-kernels-kernel-collaboration-examples/
Best regards
Ken
