Full Version: Tanget Edges - Chain Select
Show messages:  1-8  9-28  29-31
13 Aug 2024   [#29] In reply to [#28]
Must be a specific UI different than Custom UI
In any case that take the original names files existing! )
14 Aug 2024   [#30] In reply to [#28]
I see you don't have the same name as your file: ExtendEdgeSelection.js, on the drop-down menu I read: Extend Edge Selection!??
14 Aug 2024   [#31] In reply to [#30]
Hi Zooen,
The screenshot is taken when I had problem running the script. After MO's suggestion on changing the .js file's name; things started to work as they supposed to.
It means if I send u a new screenshot there u will see "ExtendEdgeSelection" instead of "Extend Edge Selection"
And I congratulate you; it seems you have keen eyes! ;-)
- Psygorn
