Full Version: Tanget Edges - Chain Select
Show messages:  1-3  4-23  24-31
12 Aug 2024   [#24] In reply to [#23]
@Pilou, Nothing will be easier, more efficient or faster than a keyboard shortcut.
For the record, if Psygorn had created a keyboard shortcut from the "Extend Edges Selection.js" file, i.e. with spaces, the script would have worked, as style7 happily used it!
12 Aug 2024   [#25] In reply to [#24]
@ Zoen
Sure ...it's just another solution to the Custom UI list when you don't love infinity of Shortcuts to memorize! :)
12 Aug 2024   [#26] In reply to [#19]
Hi MO,
It works now! I changed the name to "ExtendEdgeSelection"
By the way I did not run the script by typing in the input field nor a short key! I simply choose it from scripts menu and it didn't work!
but now it works! after applying your simple remedy. :-)
-Psygorn
12 Aug 2024   [#27] In reply to [#26]
Have you an image of your scripts menu ?
13 Aug 2024   [#28] In reply to [#27]
Yes Pilou,
Here:
13 Aug 2024   [#29] In reply to [#28]
Must be a specific UI different than Custom UI
In any case that take the original names files existing! )
14 Aug 2024   [#30] In reply to [#28]
I see you don't have the same name as your file: ExtendEdgeSelection.js, on the drop-down menu I read: Extend Edge Selection!??
14 Aug 2024   [#31] In reply to [#30]
Hi Zooen,
The screenshot is taken when I had problem running the script. After MO's suggestion on changing the .js file's name; things started to work as they supposed to.
It means if I send u a new screenshot there u will see "ExtendEdgeSelection" instead of "Extend Edge Selection"
And I congratulate you; it seems you have keen eyes! ;-)
- Psygorn
