Full Version: Another filleting issue
Show messages: All  1-3  4-9
8 Aug 2024   [#4] In reply to [#3]
Hey Michael, thank you for the detailed explanation.
In my file I actually booleaned the 2 parts so they are one but if I'd like to fillet the part to the end of the yellow line, what would you suggest I do?
8 Aug 2024   [#5] In reply to [#4]
Hi Gunter, it kind of looks like there is a little shelf-like structure in this area here:
I'll see if I can clear that out for you to give fillets a better chance.
8 Aug 2024   [#6] In reply to [#4]
Hi Gunter, please try with this attached version:
Recessed container2.3dm
8 Aug 2024   [#7]
Hey Michael, you're right, I deleted that rectangle and it worked!
Thank you so much!
Gunter
8 Aug 2024   [#8]
Hello,
Booleans can be a good option in this case.
1. Draw solid > Box
2. Draw curve > Circles aligned to Box
3. Select circles, Construct > Boolean > Isect
4. Select box, Construct > Boolean > Diff, select isect solid
5. Draw curve > Circles, align, select circle, Construct > Extrude
6. Select hollowed box solid, Construct > Boolean > Diff, select cylinder
7. Fillet box / cylinder edges
8. Fillet inside box edges
Boolean Box
8 Aug 2024   [#9] In reply to [#8]
Hey OSTexo,
This is very helpful, thank you!
