Full Version: Another filleting issue
7 Aug 2024   [#1]
Hi All,
I'm clearly not getting filleting. The yellow line show what I would like filleted but when ever I do, the fillet extends beyond the lines:
What am I not getting?
Thank you in advance!
Gunter
Recessed container.3dm
7 Aug 2024   [#2] In reply to [#1]
Hi Gunter, so a couple of things - first, the piece I'm showing here in yellow is a separate object:
If you click and drag on it you can see that you can freely move it separate from the other piece:
So that's one thing - edge fillets do not know how to cross over to some other totally separate object, the objects need to be combined together for the pieces to fillet with each other.
7 Aug 2024   [#3] In reply to [#1]
Hi Gunter, so the other thing is the fillet will get extended because a spot like this is not a place where a fillet can end:
The fillet wants to intersect with a kind of "capping face" and there is not any such face at that spot.
So instead of opening up a hole in the object there, it will continue on until it finds a suitable face for the fillet to be intersected with like this one shown in yellow here:
8 Aug 2024   [#4] In reply to [#3]
Hey Michael, thank you for the detailed explanation.
In my file I actually booleaned the 2 parts so they are one but if I'd like to fillet the part to the end of the yellow line, what would you suggest I do?
8 Aug 2024   [#5] In reply to [#4]
Hi Gunter, it kind of looks like there is a little shelf-like structure in this area here:
I'll see if I can clear that out for you to give fillets a better chance.
8 Aug 2024   [#6] In reply to [#4]
Hi Gunter, please try with this attached version:
Recessed container2.3dm
8 Aug 2024   [#7]
Hey Michael, you're right, I deleted that rectangle and it worked!
Thank you so much!
Gunter
8 Aug 2024   [#8]
Hello,
Booleans can be a good option in this case.
1. Draw solid > Box
2. Draw curve > Circles aligned to Box
3. Select circles, Construct > Boolean > Isect
4. Select box, Construct > Boolean > Diff, select isect solid
5. Draw curve > Circles, align, select circle, Construct > Extrude
6. Select hollowed box solid, Construct > Boolean > Diff, select cylinder
7. Fillet box / cylinder edges
8. Fillet inside box edges
Boolean Box
8 Aug 2024   [#9] In reply to [#8]
Hey OSTexo,
This is very helpful, thank you!
