Hi All,
I would like to fillet the internal edges of a ring shank but I am only able to fillet one side. When I click on the opposite edge, nothing happens.
I don't understand why - thank you in advance for any help!
Gunter
Mens ring size S.3dm
All is fine!
It's because you select a"closed curve" and not a "closed Edge!" ;)
So kill or hide the curves then Fillet!
Only "EDGE(S)" of a volume can be filleted !!!
Curves alones can be Filleted!
Edges of surface can't be Filleted!
The same "surface" will be not!
If you want Fillet this "surface" copy move its perimeter, Join, Fillet it then make the surface! :)
Pilou, brilliant thank you!! So simple but it caused a lot of frustration
