Full Version: Boolean
Show messages: All  1-5  6-20
Message 11501.6 was deleted
5 Aug 2024   [#7] In reply to [#6]
Yep this one! ;)
No specific problem!
As you see the generic curve of the sphere don't interefere with the volumes
so boolean & Insert are possible easily!
- The trick is to click on a "Face(s)" and not on "Solid(s)"! (otherwise the function Insert won't work)
- here "Inward" + "Groove" on the top face!
- Union of Top & Bottom Solids
- then Shell on top and Fillet on some edges!
Message 11501.8 was deleted
6 Aug 2024   [#9] In reply to [#8]
Boolean Diff (Native tools)
For The X, Y, Z tools Show me a name, an address or an image of something...! :)
Message 11501.10 was deleted
7 Aug 2024   [#11] In reply to [#10]
So...the all detailed process...
the only difficulty is to click for select Face and not Solid as said previously! ;)
If something is not clear don't hesitate! :)
Ps it's a good thing to put the objects above the gride and not outside on the empty space! ;)
7 Aug 2024   [#12]
So with the Free Alpaca! :) (100 free images by day )
Here i take this image as Style ;)
You can take only one image as style in free ...but you can take image after one for a render ;)
7 Aug 2024   [#13]
so... etc...
Message 11501.14 was deleted
7 Aug 2024   [#15] In reply to [#14]
It's free and Online! https://www.alpacaml.com
100 images free /days... i use quasi all in free! ;)
Very easy! :)
I have a little page about it! :)
https://moiscript.weebly.com/alpaca.html
They have also a free classical 2D prog (local) but you can yet make quasi anything you want with the above! :)
https://firealpaca.com/
Moi's Tuto = 20 second
each Image = 5 seconds!
yes it's magical! ;)
Message 11501.16 was deleted
10 Aug 2024   [#17] In reply to [#16]
times in seconds is the total time for make the tutotorial
and then for make an image!
And yes Alpaca is free for 100 images every day!
so 20 +5 = 25 seconds for make the first image
then 5 seconds for make any more image from the first one! ;)
Example with another one free one Ai Vizcom! ;)
https://www.vizcom.ai
(with the same Moi3D tutorial)
Message 11501.18 was deleted
11 Aug 2024   [#19] In reply to [#18]
if you have any problems with these 2 free Ai above or others inside my meminder don't hesitate! ;)
https://moiscript.weebly.com/stable-diffusion.html
Message 11501.20 was deleted
