Full Version: Flipped normals on export on a solid
Show messages: All  1-5  6-11
3 Aug 2024   [#6] In reply to [#1]
It appears to be these 2 faces here, if these are removed the orientation is ok:
3 Aug 2024   [#7] In reply to [#6]
There's an edge in there that's squashed down to to a point.
3 Aug 2024   [#8] In reply to [#1]
Hi Billabong, please try with this attached version. I removed the squashed edges (using untrim) that were on those 2 faces.
Cockpit_Plipped2_3dm.zip
3 Aug 2024   [#9] In reply to [#5]
Hey Michael,
Sorry for the late reply. Thank you so much for fixing this. If you have a min. can you explain in some more detail on how you found the error? Did you just export out sections and bring that into 3D package to see if the problem?
@ PaQ,
Thank you for trying as well. It so much appreciated.
-B
3 Aug 2024   [#10] In reply to [#9]
Hi Billabong,
Yes I broke it up into chunks and noticed that some pieces were exporting unified normals ok. So I took those pieces and gradually made them larger.
3 Aug 2024   [#11] In reply to [#10]
Understood. Thank you again
