Full Version: Flipped normals on export on a solid
Show messages: All  1  2-11
3 Aug 2024   [#2] In reply to [#1]
Hello, I have no idea why it's a mess like this.
A temp "fix" is to export your model as .igs and reload it.
While the model will not be a solid anymore (they are a bunch of naked edges that I have no clue how to correct), at least you should get a better .FBX export when it comes to flipped surfaces.
An other oddity is that separate and rejoin all the surfaces in MoI also break the solid state (you end up with an joined srf model), but for some reason the "naked" script don't show any open edge :/.
3 Aug 2024   [#3] In reply to [#1]
Hi Billabong, I think it has something to do with this area here:
If I separate out that piece then it gets a consistent orientation for everything else.
I'm still narrowing it down to try and find what is going wrong in that spot.
3 Aug 2024   [#4] In reply to [#3]
Hi Michael, how do you manage to isolate the problematic area ? was it just a guess ?
3 Aug 2024   [#5] In reply to [#4]
Hi PaQ, I tried testing some isolated chunks of the model and saw that they were making consistent normals ok and with repeated testing narrowed it down to that area.
Now I'll see if I can narrow it down further yet, there is probably a damaged trim boundary in there somewhere.
3 Aug 2024   [#6] In reply to [#1]
It appears to be these 2 faces here, if these are removed the orientation is ok:
3 Aug 2024   [#7] In reply to [#6]
There's an edge in there that's squashed down to to a point.
3 Aug 2024   [#8] In reply to [#1]
Hi Billabong, please try with this attached version. I removed the squashed edges (using untrim) that were on those 2 faces.
Cockpit_Plipped2_3dm.zip
3 Aug 2024   [#9] In reply to [#5]
Hey Michael,
Sorry for the late reply. Thank you so much for fixing this. If you have a min. can you explain in some more detail on how you found the error? Did you just export out sections and bring that into 3D package to see if the problem?
@ PaQ,
Thank you for trying as well. It so much appreciated.
-B
3 Aug 2024   [#10] In reply to [#9]
Hi Billabong,
Yes I broke it up into chunks and noticed that some pieces were exporting unified normals ok. So I took those pieces and gradually made them larger.
3 Aug 2024   [#11] In reply to [#10]
Understood. Thank you again
