Show messages: All
1-7
8-9
Hi Larry,
> If so, would it be reasonable (possible) for MOI to warn when an operation produces object(s) whose
> "type" is lower in the hierarchy than they were when the operation commenced?
It would be hard to do this for everything because there are some functions (Edit > Separate, Trim) where their job is specifically to produce a "lower" result.
It could be good for booleans though.
The complication is that there is not an established UI mechanism for reporting a command specific error.
I have some ideas on making a command "epilogue" dialog that could work for that, I hope to be able to experiment with it in v6.
Thanks Michael,
Sounds like this would make a good wish-list item combined with your command "epilogue" dialog to check for degraded object types from certain ops like the booleans.
--Larry
Show messages: All
1-7
8-9
