Full Version: SVG export question / request
Show messages: All  1-5  6-7
28 Jul 2024   [#6] In reply to [#5]
Also you might try setting visible line widths to 0 and see if they are then ignored by your receiving application.
I'll also set it up for the upcoming v5 beta that if you set visible line width to less than zero (for example set it to -1) it will omit them from the export.
29 Jul 2024   [#7] In reply to [#6]
Thank you for the 'pixel' line width clarification. Simple and should be cross-platform / app friendly.
Zero line width...
When I set the line width to zero in MoI3D and export to Affinity Designer, AFD includes the visible lines with 0 px width. Your negative line width solution to omit the visible lines sounds perfect... very simple/user friendly!
Thanks again.
Scott
