Full Version: Boolean
Show messages:  1-15  16-22
29 Jul 2024   [#16] In reply to [#13]
Hi Pilou & Booleano - it isn't possible to apply a flat 2D plane onto a sphere without stretching or compression.
It's just a fundamental fact of geometry.
That's why Flow is not going to be the right tool for doing that.
Again, the technique that can be used for modeling a polyhedral shape is to draw polygons that have shared edges and then use Transform > Rotate > "Rotate axis" to pivot the polygons upward around the shared edge.
This is described and demonstrated in these previous posts:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2140.46
http://moi3d.com/forum/index.php?webtag=MOI&msg=911.11
29 Jul 2024   [#17] In reply to [#15]
Hi Phiro,
> I think the easiest way is to use a software with a constraint resolver.
A constraint solver isn't needed - you can just draw 2 vertically oriented circles that then intersect at the needed point for rotate axis to snap on to.
More details here:
29 Jul 2024   [#18] In reply to [#16]
Yep but as adventure game that is perfect from time to time! :)
I don't desesperate to find a solution! :)
30 Jul 2024   [#19]
Another strategy...
Make a sphere from Subdivision! :)
It's winning for Flow if exists a geometric division by 6 surfaces of the soccer ball!
PS Trivial question...
Why the subdivision surface still stay in 6 separate faces and not redone a normal sphere when join or union?
30 Jul 2024   [#20] In reply to [#19]
The subdivision surface sphere is not quite exactly spherical.
Since it is not an exact match for a sphere there isn't any mechanism to try and convert it into an exact sphere.
If you want an exact sphere, you can make one with the Draw solid > Sphere command, instead of using SubD conversion.
2 Aug 2024   [#21] In reply to [#1]
Hi Booleano,
Could you tell what u want to do? What do u mean by "resolve this file" ?
- Psygorn
2 Aug 2024   [#22] In reply to [#15]
Hi Phiro,
but I think MOI is the easiest way to create this volume! :-)
-Psygorn
