Full Version: Group Therapy
Show messages: All  1-4  5-7
28 Jul 2024   [#5] In reply to [#2]
> Yes, that's the intended behavior, if you have a group selected then an edit works on the whole group including hidden sub objects.
> That's the same behavior as other programs that use groups, like Affinity Designer or Inkscape for example.
Well, I'll have to disagree with Affinity Designer and the whole rest of the world because it is an opaque convention, especially to the uninitiated.
Mio has a smoother learning curve than most every other software. That's a big reason it so beloved (IMHO).
28 Jul 2024   [#6] In reply to [#5]
Hi MindSet, in the future I want to have an additional type of hierarchical organizing tool - "folders" - which could have some different behavior than groups.
For groups though, it's safest for me to try and follow common behavior that is uniform across many apps.
If a group did not transform hidden sub objects when the parent group is moved, it would surprise other people that the group was not maintaining its structure.
Another related thing - say you have a box and hide some of the faces. If you then drag the box somewhere are you expecting the hidden faces would be left behind?
29 Jul 2024   [#7] In reply to [#6]
Michael - You are SO Good!
Thank you for explaining.
