Show messages: All
1-4
5-9
Barry, this is super helpful, thank you so much, I now understand it!
Much appreciated!
Gunter
Maybe another solution ;)
I don't how you have drawn your object
Here with the Blend
Like this you can test all generative curves
With your object
Extrude each oval (careful to kill the 2 curves and faces for have only edges!
Make the Blend : during it move the points where you want for move the seam!
Of course at the end kill the ovoïd cylinders! ;) (not shown here)
Hi Pilou, this is great learning for me, thank you so much!
Gunter
Hi there
You will get a much better flow if you reduce the surface area to flow onto , just using the outside half of the band
With a lot less distortion
cheers
shayne
Hey Shayne, thank you so much, that makes absolute sense!
Gunter
Show messages: All
1-4
5-9
