Show messages: All
1
2-9
Hi Gunter,
your issue is the seam.
You can move the seam to the inside by rotating the ovals before or after sweeping.
To generate your base surface get the calc lengths of the top and bottom ovals and sweep curve length and produce the tapered surface this gives.
You can then produce the cutouts on this surface.
Hope this helps.
Barry
Barry, thank you very much for your reply.
I have a couple of questions if I may:
1. You mention 'move the seam to the inside by rotating' - could I ask, the inside of what and how do I rotate them in that plane?
2. To generate your base surface get the calc lengths of the top and bottom ovals and sweep curve length. Is this the length you mean - see screenshot.
Many thanks in advance.
Gunter
Hi Gunter,
perhaps the attach photo may help.
Using approximate calculated lengths to form base surface mimics unwrapped swept surface.
Moving the seam by just rotating your ovals 180 degrees moves the seam to the inside.
Hope this helps.
Barry
Barry, this is super helpful, thank you so much, I now understand it!
Much appreciated!
Gunter
Maybe another solution ;)
I don't how you have drawn your object
Here with the Blend
Like this you can test all generative curves
With your object
Extrude each oval (careful to kill the 2 curves and faces for have only edges!
Make the Blend : during it move the points where you want for move the seam!
Of course at the end kill the ovoïd cylinders! ;) (not shown here)
Hi Pilou, this is great learning for me, thank you so much!
Gunter
Hi there
You will get a much better flow if you reduce the surface area to flow onto , just using the outside half of the band
With a lot less distortion
cheers
shayne
Hey Shayne, thank you so much, that makes absolute sense!
Gunter
Show messages: All
1
2-9
