Full Version: Odd issue with circular array and boolean
Show messages: All  1-2  3-8
17 Jul 2024   [#3]
You must redraw all! ;)
Your ring or gem sections and volumes are a mess of Control Points!
Rebuild fonction is your friend! But better to redraw directly!
Name your objects for a more practical selection!
Try to put the "generative curve" out of the volumes!
That avoid problem!
17 Jul 2024   [#4] In reply to [#3]
I just drew the ovals with one curve and then revolved. Do all these points come because of the flow?
And how do I reduce the number of points without having to click on each one?
Sorry for all the questions, I'm trying to understand how best to create these objects.
Many thanks!
17 Jul 2024   [#5] In reply to [#2]
Hi Peer,
Great thank you, I'm going to try that right now!
Many thanks!
Gunter
17 Jul 2024   [#6] In reply to [#4]
As i said you have 2 possibilities: select a curve section
press Tab and write Rebuild (hidden function)
Take a number of Points wished...Enter
but you have better way to redraw the section with few Control points
17 Jul 2024   [#7]
As you see my ellipsoïd volume has very few control points
When I said generative curve out any volume that is this!
if you can of course !
17 Jul 2024   [#8] In reply to [#6]
Thank you so much Pilou!
Gunter
