Full Version: Odd issue with circular array and boolean
17 Jul 2024   [#1]
Hi All,
I made this ring on which I flowed some objects. The objects were arrayed but when I boolean difference the oval ones from the ring itself, some do, some don't and some get deformed:
Been trying to figure out the problem but just can't.
Many thanks!
Gunter
17 Jul 2024   [#2] In reply to [#1]
Hi Gunter,
The problem is caused by the ovals having an edge that is very close to being coincident with the surface of the ring:
I moved one of the ovals that wasn't working away from the ring slightly:
and boolean diff worked fine then.
I don't get the deformed oval like you show. For whatever reason, that one actually worked ok for me. But, it's generally a bad idea to have surfaces or edges just grazing one another for booleans. Just like a surface has edges, some curves have points where they are joined and those points can also cause problems if they are very close to lining up with an edge or a point on the other object in the boolean.
- Peer
17 Jul 2024   [#3]
You must redraw all! ;)
Your ring or gem sections and volumes are a mess of Control Points!
Rebuild fonction is your friend! But better to redraw directly!
Name your objects for a more practical selection!
Try to put the "generative curve" out of the volumes!
That avoid problem!
17 Jul 2024   [#4] In reply to [#3]
I just drew the ovals with one curve and then revolved. Do all these points come because of the flow?
And how do I reduce the number of points without having to click on each one?
Sorry for all the questions, I'm trying to understand how best to create these objects.
Many thanks!
17 Jul 2024   [#5] In reply to [#2]
Hi Peer,
Great thank you, I'm going to try that right now!
Many thanks!
Gunter
17 Jul 2024   [#6] In reply to [#4]
As i said you have 2 possibilities: select a curve section
press Tab and write Rebuild (hidden function)
Take a number of Points wished...Enter
but you have better way to redraw the section with few Control points
17 Jul 2024   [#7]
As you see my ellipsoïd volume has very few control points
When I said generative curve out any volume that is this!
if you can of course !
17 Jul 2024   [#8] In reply to [#6]
Thank you so much Pilou!
Gunter
