Show messages: All
1-7
8-11
Hi Mo,
thank you for your reply.
You are right, that's possible to use vector program like Inscape to set the line style, I personally use Affinity Designer2, but it would be nice to have such possibility inside MoI, especially if such settings - Line Style Options dialog exists already for MoI objects.
I use DashCurve script for Hidden lines too, it works perfect, but for many technical drawings, which I has to do from assembly contained many parts, so every repeatably line settings inside/outside MoI cost some time.
It would be ideal for me after check Generate hidden checkbox, if Make2D4views script would generate dashed hidden lines with color of Style = #000000 in one step, then PDF export with white surface as a background of technical drawings works OK.
MoI PDF export settings works perfectly for objects, therefore I'm sure that next beta allows similar line style settings for visible/hidden curves (wireframes) as Michael posted.
Mik
Test_AffDsgnr.pdf
Test_MoI.pdf
You can also see about this free one online! ;)
https://www.vectorpea.com/
... and
https://www.photopea.com/ for bitmaps :-)
sure! :)
https://moiscript.weebly.com/photopea.html
Show messages: All
1-7
8-11
