This one lets you set resolution to whatever your video card will pump out. I dont remember whether it does all 4 views at once or only active, but it wont change settings
It saves to clipboard so you can paste it where ever to create any image type
http://moi3d.com/forum/lmessages.php?webtag=MOI&msg=1049.5
There is also a “screen grab” type one that will just save a file for you. On petr’s MoI page. I’ll get a link then edit that in here in a second.
Here:
http://kyticka.webzdarma.cz/3d/moi/#CaptureScreenToFile
Hi Suiyan,
So you can do it either way
If you have “inline” code, you can just add it to a text file with a “.js” extension. Then the command is whatever you name it.
So from your screenshot, “alt-s” then for the command put the name of your new js file (that you added to the command or scripts folder in your install directory)
