Full Version: Modification of ImportPointFile script
Show messages: All  1  2-3
7 Apr 2024   [#2] In reply to [#1]
> In order to modify the PointImportFile script, to add the name of the text file to the object create
> (a curve), would the final line of code below do the job?
> Or is there a better example?
It looks fine to me, does it work ok?
> I would also like the whereabouts of an example of "bulk selection" of filenames to import, if possible?
If you want to process all the files in a certain directory, there is an example here of using
moi.filesystem.getFiles() to get a list of files contained within a folder,
http://moi3d.com/forum/index.php?webtag=MOI&msg=6689.2
Like this:
var files = moi.filesystem.getFiles( 'c:\\iges_files', '*.igs' );
7 Apr 2024   [#3] In reply to [#2]
Thank you very much Michael,
The ability to import all of the .xyz files in a directory should be very helpful.
I will do some testing...for both coding.
