Full Version: Import obj/fbx into MoI with zero subdivisions...
Show messages: All  1  2-5
2 Apr 2024   [#2] In reply to [#1]
Hi Rich,
> Is there a way to bring in an obj/fbx into MoI with zero subdivisions using the Create command?
No, the SubD > Create > From File method is focused on converting the sub-d "limit surface" to NURBS geometry.
Zero subdivisions would result in polygons, not a smooth surface and MoI is not focused on polygon modeling.
There is a converter here which you can use to convert polygons to wireframe lines that you can bring in though:
http://moi3d.com/resources#Obj23dmWireframe_converter
2 Apr 2024   [#3] In reply to [#1]
Max's ImportObj Command does this.
Just be aware that thousands of little planar nubs surfaces get heavy quick.
So basic cages..
3 Apr 2024   [#4]
Hi all - yes aware of all the polygon restrictions / size problems just thought there might be some optimisation involved outside of Max's plug but I'll just use that instead!
Thanks!
// Rich
3 Apr 2024   [#5] In reply to [#4]
Hi Rich,
Sorry, no the main optimization is just not to do that. MoI is not designed to work with faceted polygon mesh data for modeling, it is better to use a polygon mesh editing program to work on that kind of data.
