Show messages: All
1-2
3
Hi Ronni, when you extrude a circle the resulting cylinder will have what is called a "seam edge" on it, which is a normal part of the structure of NURBS surfaces.
The new ACIS fillet engine in MoI v5 is much better at processing fillets that need to cross over those types of edges, so make sure you are running the current v5 beta (version Dec-1-2023) which you can get from
https://moi3d.com/beta.htm .
If you have an example of a fillet failing to cross a seam edge with the current v5 beta release please send the file to me at
moi@moi3d.com so I can investigate it and possibly send it to the ACIS developers to get it fixed.
Show messages: All
1-2
3
