Show messages: All
1-4
5-11
Thought that was going to be case with the curve fillets - im still working on the workflow its seems to be working 99% of the time very now and then I get an isolated node in the middle of a 3d polyline curve made from multi segments where the angles are large definitely works 100% of the time but in zones where its very slight rotations every now then I get the odd node that fails maybe its the slight angle in 3d space from 1 segment to next. Ill keep playing with it and see if I can isolate one and send it to you to look at. Currently its mostly working which is great.
Thanks Ill get back to you soon.
Hi Alex, one thing to look out for is that 2 adjacent segments will need to be coplanar for the curve fillet to be calculated.
Hi Alex,
I don't think it's possible to fillet a curve corner where the angular deviation from smoothness is less than 1 degree. Construct > Fillet includes a step where a point object is drawn at each vertex and a prompt is shown "Select corners..." but corners less than 1 degree are excluded by that step.
- Peer
It looks like the angle cutoff is different depending on whether you are filleting 2 separate individual lines versus 2 lines that are segments within the same joined polyline.
For the individual lines there is not any angle cutoff, for the joined curve there is.
Thanks for input appreciated here are a few tests I have carried out I created polyline with a vertical deviation of 0.7mm from which I could apply fillets and shell and the pipe software could still detect the bend info practically straight piece of pipe I have included a screenshot of the bend info. Once I put the curve deviation down to 0.6mm could no longer apply fillets which would back up the minimum 1 degree radius. In the reconstructed 3d polyline I have highlighted an out of range fillet node. Thanks for the info a getting a better idea of the limits to which I can push the pipe bending machine. I will play with applying 1 at a time rather then group application.
Hi Alex, so you can probably get the missing one by using Edit > Separate on the polyline and then selecting the 2 separate individual lines there as the input to Fillet.
When fillet is given 2 separate curves that's when there isn't an angle limit used.
The fillet piece will be very small though when the the lines get close to colinear.
Thanks Michael - the information provided has been very insightful into the process of converting these 3d spline curves back into usable polylines for tube bending process and understanding the limits ill post some pictures of bent pipe once we begin just been sorting files.
All the best
Alex.
Show messages: All
1-4
5-11
