Show messages: All
1-7
8-15
> It was just a test for see the nature of the 3d object given by the Ai!
> In fact that is just a quasi patato where an image is projected!
I see. But MoI does not really work very well as an "obj file viewer", the SubD conversion is meant to process a specific kind of OBJ mesh that has been set up to be processed with subdivision smoothing.
Other programs would be better to use for viewing an .obj file's structure. MoI is not designed to be used for that.
Yep but they are all gaz engine! :)
In Moi that is just one button...and that is directly nurbs! ;)
Hey Pilou,
Instant mesh is really not great at this quad recontruction job, I usually get way better result using Quadremesher :
https://exoside.com/
While still producing cage mesh a tad complex for the Subd to Nurbs, I think it does a decent job at recreating the polyflow.
I think Rhino does have a version of that same quadremesher now too for that kind of complex mesh to Nurbs conversion.
RockQmesh.obj
Cool result...
Yep but it's not a free one! ;)
In any case if i really wanted i have Zbrush or 3DCoat for this sort of process... ;)
And I pretty sure that the free Meshlab can do it also but not in so easy way!
Well it's basically zremesher as standalone for most DCC ... if we talk about price Zbrsuh is like 500$/year subscription only now ?
Instant mesh was a nice milestone, but it's really bad ... main flow direction is often weird, high valance points are all cluttered (reason your Nurbs conversion is so badly diced). On the top it often create non watertight mesh and even broken geometry. I mean if you a really interest to quickly convert scan/triangulated soup data into "usable" nurbs model I don't think there is any better alternative for the moment (beside manual retopo)
Here a ZB result inside MOI :)
But a such gaz engine when you have not used from years! :)
I don't want to touch it!
Not exactly same repartition than your...
Also check out this options, I kinda like the "FewerPatchesMoreControlPoints" flavour for those kind of import :
Of course dream should be have the real 3D of the right image! :)
It's the beginning!
Very soon in free(?) Vizcom we will have that!
More in the link!
https://mailchi.mp/171557ac14e6/new-vizcom-10-release-check-out-the-updates-8377049
Don't know yet if we can export the result in 3D...with textures mapping (?)
Show messages: All
1-7
8-15
